Ana içeriğe geç
Sony DSC-RX100MA Screen Replacement
Neye ihtiyacın var
    1. Sony DSC-RX100MA Screen Replacement, Back Cover: adım 1, 3 resimden 1. Sony DSC-RX100MA Screen Replacement, Back Cover: adım 1, 3 resimden 2. Sony DSC-RX100MA Screen Replacement, Back Cover: adım 1, 3 resimden 3.
      • Remove battery by sliding the tab to open the cover
      FixBot'a Sor
      Yorum Ekle
    2. Sony DSC-RX100MA Screen Replacement: adım 2, 3 resimden 1. Sony DSC-RX100MA Screen Replacement: adım 2, 3 resimden 2. Sony DSC-RX100MA Screen Replacement: adım 2, 3 resimden 3.
      • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
      • All screws in the camera can be removed with the PH 0 driver head.
      FixBot'a Sor
      Yorum Ekle
    3. Sony DSC-RX100MA Screen Replacement: adım 3, 3 resimden 1. Sony DSC-RX100MA Screen Replacement: adım 3, 3 resimden 2. Sony DSC-RX100MA Screen Replacement: adım 3, 3 resimden 3.
      • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
      • Remove the marked 2.5 mm screws with the screwdriver
      FixBot'a Sor
      Yorum Ekle
    4. Sony DSC-RX100MA Screen Replacement: adım 4, 2 resimden 1. Sony DSC-RX100MA Screen Replacement: adım 4, 2 resimden 2.
      • Using the plastic opening tools, carefully pry off the bottom plate.
      • Do not pull too hard as you may break the plastic casing.
      FixBot'a Sor
      Yorum Ekle
    5. Sony DSC-RX100MA Screen Replacement: adım 5, 3 resimden 1. Sony DSC-RX100MA Screen Replacement: adım 5, 3 resimden 2. Sony DSC-RX100MA Screen Replacement: adım 5, 3 resimden 3.
      • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
      • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
      FixBot'a Sor
      Yorum Ekle
    6. Sony DSC-RX100MA Screen Replacement: adım 6, 2 resimden 1. Sony DSC-RX100MA Screen Replacement: adım 6, 2 resimden 2.
      • Remove the back cover
      FixBot'a Sor
      Yorum Ekle
    1. Sony DSC-RX100MA Screen Replacement, Screen: adım 7, 3 resimden 1. Sony DSC-RX100MA Screen Replacement, Screen: adım 7, 3 resimden 2. Sony DSC-RX100MA Screen Replacement, Screen: adım 7, 3 resimden 3.
      • Move side panel to get access to screws
      • Remove two screws (black 2.5mm) with PH #0 screwdriver
      FixBot'a Sor
      Yorum Ekle
    2. Sony DSC-RX100MA Screen Replacement: adım 8, 2 resimden 1. Sony DSC-RX100MA Screen Replacement: adım 8, 2 resimden 2.
      • Remove back panel assembly while still keeping ribbon cable attached
      • Be very gentle and care not to tear the gold ribbon cable. This will be a common theme throughout these replacement guides.
      FixBot'a Sor
      Yorum Ekle
    3. Sony DSC-RX100MA Screen Replacement: adım 9, 2 resimden 1. Sony DSC-RX100MA Screen Replacement: adım 9, 2 resimden 2.
      • Carefully unplug ribbon connector to fully detach LCD screen assembly from camera
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
KC Egger
315 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-1, Maness Winter 2017 Cal Poly, Team 21-1, Maness Winter 2017 üyesi
CPSU-MANESS-W17S21G1
5 Üyeler
10 adet Kılavuz yazıldı
5Kılavuz Yorumları
Any idea where I can get a set or replacement screws? one came out of my LCD joint and I can’t find replacements anywhere online. I’ve even tried Ebay.
Alberto Lora - Yanıt Paylaş
Definately be careful with the gold ribbon cable, looked at mine funny and it just snapped in two.. waiting on a replacement now :(
Connor Quinn - Yanıt Paylaş
I’ve ripped 2 of these before - not fun! Still… cheap enough to buy but delivery took a couple of weeks.
I had a cracked screen so had to take this out to replace as well - problem i’ve had is that although i stuck it down really well (with 3M 1mm double-sided tape, it doesn’t hold great and so the screen has risen a bit and doesn’t sit flush.
Just in the process now of sticking it down again but with a touch of superglue as i need it to hold down a bit better - that should hopefully be me done then :)
Great guide by the way KC Egger - thanks for taking the time to put this together - it’s been a life saver for me!
Jamie Dunkley - Yanıt Paylaş
Where did you purchase your screen, I’ve been trying to find one from Sony parts dealers and can’t find it. Any links would be helpful, thanks.
Ian Cullen - Yanıt Paylaş
Probably a late reply but I got my screen from AliExpress, there are still a lot of them for sale and the sellers include a ribbon cable with the screen.
For these cameras the official screen protector is Sony PCK-LM15 Screen Protector
I think mine was damaged by sunscreen on my hands when using the camera over summer so putting a protective layer on top should help preserve the new screen.
Andrew Fox - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 27
Son 30 gün: 119
Her zaman: 7,094
