Ana içeriğe geç
Sony DSC-RX10M3 Back and Right Panel Replacement
Neye ihtiyacın var
  1. Sony DSC-RX10M3 Back and Right Panel Replacement, Battery Replacement: adım 1, 1 resimden 1.
    • Turn off the Device by scrolling the tab to "OFF" indicated by the arrow.
    FixBot'a Sor
    Yorum Ekle
  2. Sony DSC-RX10M3 Back and Right Panel Replacement: adım 2, 3 resimden 1. Sony DSC-RX10M3 Back and Right Panel Replacement: adım 2, 3 resimden 2. Sony DSC-RX10M3 Back and Right Panel Replacement: adım 2, 3 resimden 3.
    • Remove the battery located at the bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Sony DSC-RX10M3 Back and Right Panel Replacement, Back and Right Panel: adım 3, 1 resimden 1.
    • Remove the twelve 0.7mm Phillips #000 screws from the bottom case.
    FixBot'a Sor
    Yorum Ekle
  4. Sony DSC-RX10M3 Back and Right Panel Replacement: adım 4, 2 resimden 1. Sony DSC-RX10M3 Back and Right Panel Replacement: adım 4, 2 resimden 2.
    • Remove the two 0.7mm screws that secure the right side of the camera.
    • Remove the two 0.7mm screws that secure the left side of the camera, near the Wi-Fi logo and charging port.
    FixBot'a Sor
    Yorum Ekle
  5. Sony DSC-RX10M3 Back and Right Panel Replacement: adım 5, 2 resimden 1. Sony DSC-RX10M3 Back and Right Panel Replacement: adım 5, 2 resimden 2.
    • Gently pull off the plastic eye guard.
    FixBot'a Sor
    Yorum Ekle
  6. Sony DSC-RX10M3 Back and Right Panel Replacement: adım 6, 2 resimden 1. Sony DSC-RX10M3 Back and Right Panel Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the four 0.4mm screws located under the rubber eye guard.
    • Use a plastic opening tool to detach the back panel of the camera.
    FixBot'a Sor
    Yorum Ekle
  7. Sony DSC-RX10M3 Back and Right Panel Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • This is a tight spot; make sure you use minimal force when removing the cover.
    • Using tweezers, disconnect the ribbon cable connecting the LCD to the circuit board.
    FixBot'a Sor
    Yorum Ekle
  8. Sony DSC-RX10M3 Back and Right Panel Replacement: adım 8, 1 resimden 1.
    • This step is only needed if you wish to remove the right side panel.
    • Use a plastic openeing tool to gently detach the right panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Salman Hersi
339 İtibar
2 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 67
Her zaman: 1,934
