Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
In order to access the internals of the device, the cover must be removed. If there is a problem with one of the components on the cover, it may need to be replaced.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the five exposed 7.9 mm phillips screws with the spudger.
    • Remove the five exposed 7.9 mm phillips screws with the spudger.
    • Punch through the warranty sticker with the spudger and remove the screw underneath.
  2. Remove the rubber feet with the screwdriver.
    • Remove the rubber feet with the screwdriver.
    • Remove the screws that the rubber feet were covering.
  3. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Lift up the cover gently.
    • Lift up the cover gently.
    • The tray is still connected to the base with wires.
  5. Remove the wires with tweezers by gently pulling on the base they are attached to.
    • Remove the wires with tweezers by gently pulling on the base they are attached to.
Sonuç
Rogelio Garcia
13 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 11-21, Maness Winter 2012 Cal Poly, Team 11-21, Maness Winter 2012 üyesi
CPSU-MANESS-W12S11G21
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,310
