Ana içeriğe geç
Sony DVP-FX730 Laser Replacement
Neye ihtiyacın var
  1. Sony DVP-FX730 Laser Replacement, Cover: adım 1, 1 resimden 1.
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Laser Replacement: adım 2, 1 resimden 1.
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Laser Replacement: adım 3, 1 resimden 1.
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Laser Replacement: adım 4, 1 resimden 1.
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Laser Replacement, Laser: adım 5, 2 resimden 1. Sony DVP-FX730 Laser Replacement, Laser: adım 5, 2 resimden 2.
    • Remove the large connector.
    • Remove the small connector.
  6. Sony DVP-FX730 Laser Replacement: adım 6, 1 resimden 1.
    • Remove Philips screws with the #0 Philips Screwdriver.
  7. Sony DVP-FX730 Laser Replacement: adım 7, 1 resimden 1.
    • Lift up the black piece connected to the wires.
    • Lift gently because the ribbon cable is attached to the bottom.
  8. Sony DVP-FX730 Laser Replacement: adım 8, 2 resimden 1. Sony DVP-FX730 Laser Replacement: adım 8, 2 resimden 2.
    • Unlock the lock clip
  9. Sony DVP-FX730 Laser Replacement: adım 9, 1 resimden 1.
    • Remove the T6 screws with the T6 screwdriver.
  10. Sony DVP-FX730 Laser Replacement: adım 10, 1 resimden 1.
    • Gently pull the rods out with tweezers.
    • Be sure the laser is out of the way so that the rods can be removed.
  11. Sony DVP-FX730 Laser Replacement: adım 11, 2 resimden 1. Sony DVP-FX730 Laser Replacement: adım 11, 2 resimden 2.
    • Pull laser off of the rods.
    • Be careful when removing the rods because a fragile metal piece may break.
  12. Sony DVP-FX730 Laser Replacement: adım 12, 1 resimden 1.
    • The laser is now removed.
Sonuç
Oliver Woolsoncroft
78 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-21, Maness Winter 2012 Cal Poly, Team 11-21, Maness Winter 2012 üyesi
CPSU-MANESS-W12S11G21
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
where do I buy the lens?
mnmmacd - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 19
Her zaman: 4,701
