Ana içeriğe geç
Sony DVP-FX730 Monitor Replacement
Neye ihtiyacın var
  1. Sony DVP-FX730 Monitor Replacement, Cover: adım 1, 1 resimden 1.
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Monitor Replacement: adım 2, 1 resimden 1.
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Monitor Replacement: adım 3, 1 resimden 1.
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Monitor Replacement: adım 4, 1 resimden 1.
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Monitor Replacement, Monitor: adım 5, 2 resimden 1. Sony DVP-FX730 Monitor Replacement, Monitor: adım 5, 2 resimden 2.
    • Use your hand to remove the small back cover by gently pulling upward.
  6. Sony DVP-FX730 Monitor Replacement: adım 6, 1 resimden 1.
    • Using a screwdriver, remove the two 12 mm pan head screws.
  7. Sony DVP-FX730 Monitor Replacement: adım 7, 1 resimden 1.
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  8. Sony DVP-FX730 Monitor Replacement: adım 8, 2 resimden 1. Sony DVP-FX730 Monitor Replacement: adım 8, 2 resimden 2.
    • Remove the wires attached to the white base using tweezers to pull them up.
  9. Sony DVP-FX730 Monitor Replacement: adım 9, 2 resimden 1. Sony DVP-FX730 Monitor Replacement: adım 9, 2 resimden 2.
    • Referring back to Step 8, do the same with the wires attached to the black base.
  10. Sony DVP-FX730 Monitor Replacement: adım 10, 1 resimden 1.
    • The screen should now be completely separated from the main device.
Sonuç
Andrew Ward
93 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-21, Maness Winter 2012 Cal Poly, Team 11-21, Maness Winter 2012 üyesi
CPSU-MANESS-W12S11G21
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 3,013
