Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
Punch through the warranty sticker with the spudger.
Remove the screw underneath with the Phillips screwdriver.
Remove the rubber feet using the spudger.
Remove the screws that were covered by the rubber feet.
Hold on to the corners of the cover and gently lift the cover.
Gently remove the wires with tweezers by pulling up on the base they are attached to.
Use your hand to remove the small back cover by gently pulling upward.
Using a screwdriver, remove the two 12 mm pan head screws.
Remove the wires attached to the white base using tweezers to pull them up.
Referring back to Step 8, do the same with the wires attached to the black base.
The screen should now be completely separated from the main device.
