Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use your hand to remove the small back cover by gently pulling upward.
Using a screwdriver, remove the two 12 mm pan head screws.
Bu adımda kullanılan alet:Tweezers$4.99-
Remove the wires attached to the white base using tweezers to pull them up.
Referring back to Step 8, do the same with the wires attached to the black base.
The screen should now be completely separated from the main device.
Remove the four rubber feet and the screws beneath.
Remove the two exposed screws on the left side.
Pull back the cables until the screw is visible.
Using the spudger, separate the top and bottom covers.
Using spudger, push the lock clips to unlock the ribbon cable.
Using tweezers, pull the connector loose.
Place your hand on the front of the screen and push upwards.
2 farklı kişi bu kılavuzu tamamladı.
