Ana içeriğe geç
Sony DVP-NS325 Motherboard Replacement
Neye ihtiyacın var
  1. Sony DVP-NS325 Motherboard Replacement, Outer Case: adım 1, 3 resimden 1. Sony DVP-NS325 Motherboard Replacement, Outer Case: adım 1, 3 resimden 2. Sony DVP-NS325 Motherboard Replacement, Outer Case: adım 1, 3 resimden 3.
    • Use a Phillips screwdriver to unscrew the five screws.
  2. Sony DVP-NS325 Motherboard Replacement: adım 2, 3 resimden 1. Sony DVP-NS325 Motherboard Replacement: adım 2, 3 resimden 2. Sony DVP-NS325 Motherboard Replacement: adım 2, 3 resimden 3.
    • Use the Philips screwdriver to remove the screws located on the sides and the back.
    • Not shown are the right side screw and the middle screw.
  3. Sony DVP-NS325 Motherboard Replacement: adım 3, 1 resimden 1.
    • Use a spudger to separate the case from the chassis.
    • Remove the case.
  4. Sony DVP-NS325 Motherboard Replacement, Motherboard: adım 4, 3 resimden 1. Sony DVP-NS325 Motherboard Replacement, Motherboard: adım 4, 3 resimden 2. Sony DVP-NS325 Motherboard Replacement, Motherboard: adım 4, 3 resimden 3.
    • Remove all cables that are connected to the motherboard by pulling upwards from the motherboard.
    • Grip as close to the connectors as possible. Avoid pulling on the wires/ribbon cables.
  5. Sony DVP-NS325 Motherboard Replacement: adım 5, 1 resimden 1.
    • Use a Phillips screwdriver to remove all screws located in the 4 corners of the motherboard.
  6. Sony DVP-NS325 Motherboard Replacement: adım 6, 1 resimden 1.
    • Pull the motherboard up and out of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
madison mathis
357 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 75
