Giriş
The removal of the outer case of the Sony DVP-NS325 is necessary to gain access to the motherboard and other components. Without removing this piece you will not be able to replace/repair any parts in the next 4 guides.
For this guide, you will need a Phillips screw driver to remove the outer case.
Neye ihtiyacın var
Bir başkası bu kılavuzu tamamladı.
