Ana içeriğe geç
Sony DVP-NS325 Power Cable Replacement
Neye ihtiyacın var
  1. Sony DVP-NS325 Power Cable Replacement, Outer Case: adım 1, 3 resimden 1. Sony DVP-NS325 Power Cable Replacement, Outer Case: adım 1, 3 resimden 2. Sony DVP-NS325 Power Cable Replacement, Outer Case: adım 1, 3 resimden 3.
    • Use a Phillips screwdriver to unscrew the five screws.
    FixBot'a Sor
    Yorum Ekle
  2. Sony DVP-NS325 Power Cable Replacement: adım 2, 3 resimden 1. Sony DVP-NS325 Power Cable Replacement: adım 2, 3 resimden 2. Sony DVP-NS325 Power Cable Replacement: adım 2, 3 resimden 3.
    • Use the Philips screwdriver to remove the screws located on the sides and the back.
    • Not shown are the right side screw and the middle screw.
    FixBot'a Sor
    Yorum Ekle
  3. Sony DVP-NS325 Power Cable Replacement: adım 3, 1 resimden 1.
    • Use a spudger to separate the case from the chassis.
    • Remove the case.
    FixBot'a Sor
    Yorum Ekle
  4. Sony DVP-NS325 Power Cable Replacement, Power Cable: adım 4, 2 resimden 1. Sony DVP-NS325 Power Cable Replacement, Power Cable: adım 4, 2 resimden 2.
    • Unscrew all screws using a Phillips screwdriver removing the outer case to access the power cable.
    FixBot'a Sor
    Yorum Ekle
  5. Sony DVP-NS325 Power Cable Replacement: adım 5, 2 resimden 1. Sony DVP-NS325 Power Cable Replacement: adım 5, 2 resimden 2.
    • Using a finger, press down on the clip to remove the connector for the cable.
    FixBot'a Sor
    Yorum Ekle
  6. Sony DVP-NS325 Power Cable Replacement: adım 6, 1 resimden 1.
    • Using two fingers, press in both the top and bottom clips to release the holder for the power cable to remove the cable completely.
    FixBot'a Sor
    Yorum Ekle
  7. Sony DVP-NS325 Power Cable Replacement: adım 7, 1 resimden 1.
    • Pull the cable out of the case to fully replace the cable.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 294
