Ana içeriğe geç
Sony DVP-NS325 Power Supply Board Replacement
Neye ihtiyacın var
  1. Sony DVP-NS325 Power Supply Board Replacement, Outer Case: adım 1, 3 resimden 1. Sony DVP-NS325 Power Supply Board Replacement, Outer Case: adım 1, 3 resimden 2. Sony DVP-NS325 Power Supply Board Replacement, Outer Case: adım 1, 3 resimden 3.
    • Use a Phillips screwdriver to unscrew the five screws.
  2. Sony DVP-NS325 Power Supply Board Replacement: adım 2, 3 resimden 1. Sony DVP-NS325 Power Supply Board Replacement: adım 2, 3 resimden 2. Sony DVP-NS325 Power Supply Board Replacement: adım 2, 3 resimden 3.
    • Use the Philips screwdriver to remove the screws located on the sides and the back.
    • Not shown are the right side screw and the middle screw.
  3. Sony DVP-NS325 Power Supply Board Replacement: adım 3, 1 resimden 1.
    • Use a spudger to separate the case from the chassis.
    • Remove the case.
  4. Sony DVP-NS325 Power Supply Board Replacement, Power Cable: adım 4, 2 resimden 1. Sony DVP-NS325 Power Supply Board Replacement, Power Cable: adım 4, 2 resimden 2.
    • Unscrew all screws using a Phillips screwdriver removing the outer case to access the power cable.
  5. Sony DVP-NS325 Power Supply Board Replacement: adım 5, 2 resimden 1. Sony DVP-NS325 Power Supply Board Replacement: adım 5, 2 resimden 2.
    • Using a finger, press down on the clip to remove the connector for the cable.
  6. Sony DVP-NS325 Power Supply Board Replacement: adım 6, 1 resimden 1.
    • Using two fingers, press in both the top and bottom clips to release the holder for the power cable to remove the cable completely.
  7. Sony DVP-NS325 Power Supply Board Replacement: adım 7, 1 resimden 1.
    • Pull the cable out of the case to fully replace the cable.
  8. Sony DVP-NS325 Power Supply Board Replacement, Power Supply Board: adım 8, 2 resimden 1. Sony DVP-NS325 Power Supply Board Replacement, Power Supply Board: adım 8, 2 resimden 2.
    • Remove the wire connected to the motherboard by pulling the wire upwards.
    • Move the black holder piece out of the way in order to fully remove the wire from the area.
  9. Sony DVP-NS325 Power Supply Board Replacement: adım 9, 1 resimden 1.
    • Using a Phillips screwdriver, remove the four screws holding the motherboard in place.
    • There are three screws not shown all located on the corners of the motherboard.
  10. Sony DVP-NS325 Power Supply Board Replacement: adım 10, 1 resimden 1.
    • Remove the power supply board.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 65
