Ana içeriğe geç
Sony DVP-SR200P Button Circuit Board Replacement
Neye ihtiyacın var
  1. Sony DVP-SR200P Button Circuit Board Replacement, Top Cover: adım 1, 2 resimden 1. Sony DVP-SR200P Button Circuit Board Replacement, Top Cover: adım 1, 2 resimden 2.
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
  2. Sony DVP-SR200P Button Circuit Board Replacement: adım 2, 2 resimden 1. Sony DVP-SR200P Button Circuit Board Replacement: adım 2, 2 resimden 2.
    • Slide the cover away from the front of the DVD player until it is off.
  3. Sony DVP-SR200P Button Circuit Board Replacement, Processing Board: adım 3, 1 resimden 1.
    • Remove the blue tape from the processing board by gently pulling upward.
  4. Sony DVP-SR200P Button Circuit Board Replacement: adım 4, 2 resimden 1. Sony DVP-SR200P Button Circuit Board Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
  5. Sony DVP-SR200P Button Circuit Board Replacement: adım 5, 1 resimden 1.
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
  6. Sony DVP-SR200P Button Circuit Board Replacement: adım 6, 1 resimden 1.
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
  7. Sony DVP-SR200P Button Circuit Board Replacement, DVD Drive: adım 7, 1 resimden 1.
    • Orient the DVD player so the front of the DVD player is opposite of you.
    • Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
  8. Sony DVP-SR200P Button Circuit Board Replacement: adım 8, 1 resimden 1.
    • Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
  9. Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: adım 9, 3 resimden 1. Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: adım 9, 3 resimden 2. Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: adım 9, 3 resimden 3.
    • Orient the DVD player so the button circuit board is facing you.
    • Remove the four #1 Phillips screws (silver, 3/16") from the button circuit board.
    • Three 3/16" screws from the longer button circuit board.
    • One 3/16" screw from the smaller button circuit board.
  10. Sony DVP-SR200P Button Circuit Board Replacement: adım 10, 3 resimden 1. Sony DVP-SR200P Button Circuit Board Replacement: adım 10, 3 resimden 2. Sony DVP-SR200P Button Circuit Board Replacement: adım 10, 3 resimden 3.
    • Hold down the copper brace that is near the far right screw hole of the long circuit board.
    • Lift the longer button circuit board over the copper brace and out of its position.
  11. Sony DVP-SR200P Button Circuit Board Replacement: adım 11, 3 resimden 1. Sony DVP-SR200P Button Circuit Board Replacement: adım 11, 3 resimden 2. Sony DVP-SR200P Button Circuit Board Replacement: adım 11, 3 resimden 3.
    • Push back the black, plastic clip near the left center of the shorter button circuit board.
    • Pull the shorter button circuit board out of its position.
  12. Sony DVP-SR200P Button Circuit Board Replacement: adım 12, 2 resimden 1. Sony DVP-SR200P Button Circuit Board Replacement: adım 12, 2 resimden 2.
    • Wiggle the white cord connecting the two boards out from under the plastic pieces securing the cord.
    • Lift the button circuit board out of the DVD player.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jeffrey Powell
157 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-17, Forte Winter 2013 Cal Poly, Team 5-17, Forte Winter 2013 üyesi
CPSU-FORTE-W13S5G17
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 2,324
