Ana içeriğe geç
Sony DVP-SR200P Processing Board Replacement
Neye ihtiyacın var
  1. Sony DVP-SR200P Processing Board Replacement, Top Cover: adım 1, 2 resimden 1. Sony DVP-SR200P Processing Board Replacement, Top Cover: adım 1, 2 resimden 2.
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
    FixBot'a Sor
    Yorum Ekle
  2. Sony DVP-SR200P Processing Board Replacement: adım 2, 2 resimden 1. Sony DVP-SR200P Processing Board Replacement: adım 2, 2 resimden 2.
    • Slide the cover away from the front of the DVD player until it is off.
    FixBot'a Sor
    Yorum Ekle
  3. Sony DVP-SR200P Processing Board Replacement, Processing Board: adım 3, 1 resimden 1.
    • Remove the blue tape from the processing board by gently pulling upward.
    FixBot'a Sor
    Yorum Ekle
  4. Sony DVP-SR200P Processing Board Replacement: adım 4, 2 resimden 1. Sony DVP-SR200P Processing Board Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
    FixBot'a Sor
    Yorum Ekle
  5. Sony DVP-SR200P Processing Board Replacement: adım 5, 1 resimden 1.
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
    FixBot'a Sor
    Yorum Ekle
  6. Sony DVP-SR200P Processing Board Replacement: adım 6, 1 resimden 1.
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brian Hua
80 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-17, Forte Winter 2013 Cal Poly, Team 5-17, Forte Winter 2013 üyesi
CPSU-FORTE-W13S5G17
5 Üyeler
6 adet Kılavuz yazıldı
3Kılavuz Yorumları
I have Sony DVD player dvp at510p. After switching it runs then automatic Power go down while running it's process ic get hotter and hotter what's the right solutions plz help me
Dhiraj Vasave - Yanıt Paylaş
SO my DVD player run 5to 6 minutes then automatic stop all power goes to less
My DVD player not run but power on Bluetooth not connect
Sony - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 2,354
