Ana içeriğe geç
Sony Dream Machine ICF-C180 Speaker Replacement
Neye ihtiyacın var
  1. Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: adım 1, 3 resimden 1. Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: adım 1, 3 resimden 2. Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Detach the top of the plastic casing. Use a Phillips head screwdriver to unscrew the three bottom screws.
  2. Sony Dream Machine ICF-C180 Speaker Replacement: adım 2, 2 resimden 1. Sony Dream Machine ICF-C180 Speaker Replacement: adım 2, 2 resimden 2.
    • Wedge a plastic opening tool between the face of the clock and the body.
    • Pry open the face of the clock away from the body.
  3. Sony Dream Machine ICF-C180 Speaker Replacement: adım 3, 2 resimden 1. Sony Dream Machine ICF-C180 Speaker Replacement: adım 3, 2 resimden 2.
    • To open the top casing, pull it upward.
    • Be careful not to yank on the ribbon cable when pulling on the top casing.
  4. Sony Dream Machine ICF-C180 Speaker Replacement: adım 4, 2 resimden 1. Sony Dream Machine ICF-C180 Speaker Replacement: adım 4, 2 resimden 2.
    • Pull upward on the blue and white ribbon cables to remove them. This will make it easier to remove the speaker.
  5. Sony Dream Machine ICF-C180 Speaker Replacement: adım 5, 2 resimden 1. Sony Dream Machine ICF-C180 Speaker Replacement: adım 5, 2 resimden 2.
    • Desolder the wires going to the speaker with a soldering iron.
  6. Sony Dream Machine ICF-C180 Speaker Replacement: adım 6, 2 resimden 1. Sony Dream Machine ICF-C180 Speaker Replacement: adım 6, 2 resimden 2.
    • Use the plastic opening tool to remove the glue from the speaker.
  7. Sony Dream Machine ICF-C180 Speaker Replacement: adım 7, 2 resimden 1. Sony Dream Machine ICF-C180 Speaker Replacement: adım 7, 2 resimden 2.
    • Loosen the speaker from the remaining glue with a plastic opening tool.
    • Insert the plastic opening tool into the rail that holds the speaker and push down.
  8. Sony Dream Machine ICF-C180 Speaker Replacement: adım 8, 2 resimden 1. Sony Dream Machine ICF-C180 Speaker Replacement: adım 8, 2 resimden 2.
    • Pull the speaker upward to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Caleb John
101 İtibar
1 Kılavuz yazıldı
Bir Yorum
HEY! that's moderately adequate...
Caleb John - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 512
