Ana içeriğe geç
Sony ECM-MS907 Battery Replacement
Neye ihtiyacın var
  1. Sony ECM-MS907 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Take off the windshield from the top of the microphone and place aside. The bottom part of the microphone is detachable. In a clockwise motion, begin unscrewing the bottom of the microphone from its base.
  2. Sony ECM-MS907 Battery Replacement: adım 2, 2 resimden 1. Sony ECM-MS907 Battery Replacement: adım 2, 2 resimden 2.
    • Pull off the bottom base of the microphone. The microphone should now be in two pieces. After the bottom base is removed, the battery should now be visible.
  3. Sony ECM-MS907 Battery Replacement: adım 3, 1 resimden 1.
    • To remove the battery, push it upward into the aluminum spring. This will loosen and free the battery.
  4. Sony ECM-MS907 Battery Replacement: adım 4, 2 resimden 1. Sony ECM-MS907 Battery Replacement: adım 4, 2 resimden 2.
    • Select a new, (AA) battery to insert into the microphone. Match the (+) and (-) sides of the battery to the matching symbols inside the microphone.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kefaya
364 İtibar
3 adet Kılavuz yazıldı
Ekip
2 Yorum
Excellent tuto : clair direct et simple
Une fois avoir changé la pile, j’ai découvert qu’il y a un mauvais contact avec le bouton de commande. Quand on le manipule, le voyant s’allume 1/4 de secondes et s’éteint. Pourriez vous ‘m’indiquer un tuto pour le démontage complet du microphone Sony.
Ou bien m’indiquer un réparateur sur Paris
Merci à Kefaya et bonne soirée
henri75012@club-internet.fr
Biezin - Yanıt
Remarquable tuto, illustré par de magnifiques photos, très claires. Merci beaucoup !
DENIS PERRIN - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 4,911
