Ana içeriğe geç
Sony ECM-MS907 Microphone Disassembly
Neye ihtiyacın var
  1. Sony ECM-MS907 Microphone Disassembly, Microphone: adım 1, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the screw securing diaphragm to the base of the microphone.
  2. Sony ECM-MS907 Microphone Disassembly: adım 2, 2 resimden 1. Sony ECM-MS907 Microphone Disassembly: adım 2, 2 resimden 2.
    • Separate the microphone into two pieces to reveal the internal shield cover.
  3. Sony ECM-MS907 Microphone Disassembly: adım 3, 1 resimden 1.
    • Unscrew the base of the microphone in a clockwise motion and separate the bottom and top of the microphone.
  4. Sony ECM-MS907 Microphone Disassembly: adım 4, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the screw directly above the battery.
  5. Sony ECM-MS907 Microphone Disassembly: adım 5, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the black screw near the bottom of the microphone.
  6. Sony ECM-MS907 Microphone Disassembly: adım 6, 3 resimden 1. Sony ECM-MS907 Microphone Disassembly: adım 6, 3 resimden 2. Sony ECM-MS907 Microphone Disassembly: adım 6, 3 resimden 3.
    • Use the heavy duty spudger to detach the grip area from the microphone.
Sonuç
Kefaya
364 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 5,550
