Ana içeriğe geç
Sony Ericsson K750i Keypad Replacement
Neye ihtiyacın var
  1. Sony Ericsson K750i Keypad Replacement, Back Casing: adım 1, 1 resimden 1.
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  2. Sony Ericsson K750i Keypad Replacement: adım 2, 1 resimden 1.
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  3. Sony Ericsson K750i Keypad Replacement: adım 3, 1 resimden 1.
    • Remove the casing to expose the camera's components.
  4. Sony Ericsson K750i Keypad Replacement, Keypad: adım 4, 1 resimden 1.
    • Gently pry open the front casing by working an opening tool along the entire seam.
  5. Sony Ericsson K750i Keypad Replacement: adım 5, 1 resimden 1.
    • Remove the front casing by gently lifting it from the phone.
    • Be careful not to pull off any other delicate pieces.
  6. Sony Ericsson K750i Keypad Replacement: adım 6, 2 resimden 1. Sony Ericsson K750i Keypad Replacement: adım 6, 2 resimden 2.
    • Remove the keypad.
    • The LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
Sonuç
Abby Evers
202 İtibar
6 adet Kılavuz yazıldı
Ekip
UW Stout, Team 1-6, Zhou Fall 2011 UW Stout, Team 1-6, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S1G6
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 3,256
