Giriş
This guide will help you to remove the keypad from your Sony Ericsson T68i.
Parçalar
Hiçbir parçaya gerek yok.
  1. Remove the battery from the back. Remove the battery from the back.
    • Remove the battery from the back.
  2. Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips.
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Unscrew all four Torx T6 screws. Keep in a safe place. Keep in a safe place.
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  5. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart.
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
Sonuç
Tim Dascomb
123 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 26-34, Regan Spring 2010 Cal Poly, Team 26-34, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G34
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 1,982
