Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
After removing the screws, the two halves will separate. If not, then pry them gently apart.
Remove the circuit board and screen from the device.
Use your T6 to remove the 4 screws.
Carefully remove the plastic clips holding the screen on the board.
Remove the plate protecting the more delicate processing parts from the logic board.
