Ana içeriğe geç
Sony Ericsson T68i Speaker Replacement
Neye ihtiyacın var
  1. Sony Ericsson T68i Speaker Replacement, Keypad: adım 1, 2 resimden 1. Sony Ericsson T68i Speaker Replacement, Keypad: adım 1, 2 resimden 2.
    • Remove the battery from the back.
  2. Sony Ericsson T68i Speaker Replacement: adım 2, 3 resimden 1. Sony Ericsson T68i Speaker Replacement: adım 2, 3 resimden 2. Sony Ericsson T68i Speaker Replacement: adım 2, 3 resimden 3.
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Sony Ericsson T68i Speaker Replacement: adım 3, 3 resimden 1. Sony Ericsson T68i Speaker Replacement: adım 3, 3 resimden 2. Sony Ericsson T68i Speaker Replacement: adım 3, 3 resimden 3.
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  4. Sony Ericsson T68i Speaker Replacement: adım 4, 3 resimden 1. Sony Ericsson T68i Speaker Replacement: adım 4, 3 resimden 2. Sony Ericsson T68i Speaker Replacement: adım 4, 3 resimden 3.
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
  5. Sony Ericsson T68i Speaker Replacement, Screen: adım 5, 3 resimden 1. Sony Ericsson T68i Speaker Replacement, Screen: adım 5, 3 resimden 2. Sony Ericsson T68i Speaker Replacement, Screen: adım 5, 3 resimden 3.
    • Remove the circuit board and screen from the device.
    • Use your T6 to remove the 4 screws.
  6. Sony Ericsson T68i Speaker Replacement: adım 6, 3 resimden 1. Sony Ericsson T68i Speaker Replacement: adım 6, 3 resimden 2. Sony Ericsson T68i Speaker Replacement: adım 6, 3 resimden 3.
    • Remove the board and screen.
  7. Sony Ericsson T68i Speaker Replacement: adım 7, 3 resimden 1. Sony Ericsson T68i Speaker Replacement: adım 7, 3 resimden 2. Sony Ericsson T68i Speaker Replacement: adım 7, 3 resimden 3.
    • Carefully remove the plastic clips holding the screen on the board.
  8. Sony Ericsson T68i Speaker Replacement, Speaker: adım 8, 3 resimden 1. Sony Ericsson T68i Speaker Replacement, Speaker: adım 8, 3 resimden 2. Sony Ericsson T68i Speaker Replacement, Speaker: adım 8, 3 resimden 3.
    • Gently pry it out the speaker located in the screen housing with a small screwdriver or similar tool.
Sonuç
Tim Dascomb
159 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-34, Regan Spring 2010 Cal Poly, Team 26-34, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G34
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 10
Her zaman: 2,231
