Ana içeriğe geç
Sony Ericsson T68i Vibration Motor Replacement
Neye ihtiyacın var
  1. Sony Ericsson T68i Vibration Motor Replacement, Keypad: adım 1, 2 resimden 1. Sony Ericsson T68i Vibration Motor Replacement, Keypad: adım 1, 2 resimden 2.
    • Remove the battery from the back.
  2. Sony Ericsson T68i Vibration Motor Replacement: adım 2, 3 resimden 1. Sony Ericsson T68i Vibration Motor Replacement: adım 2, 3 resimden 2. Sony Ericsson T68i Vibration Motor Replacement: adım 2, 3 resimden 3.
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Sony Ericsson T68i Vibration Motor Replacement: adım 3, 3 resimden 1. Sony Ericsson T68i Vibration Motor Replacement: adım 3, 3 resimden 2. Sony Ericsson T68i Vibration Motor Replacement: adım 3, 3 resimden 3.
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  4. Sony Ericsson T68i Vibration Motor Replacement: adım 4, 3 resimden 1. Sony Ericsson T68i Vibration Motor Replacement: adım 4, 3 resimden 2. Sony Ericsson T68i Vibration Motor Replacement: adım 4, 3 resimden 3.
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
  5. Sony Ericsson T68i Vibration Motor Replacement, Vibration Motor: adım 5, 2 resimden 1. Sony Ericsson T68i Vibration Motor Replacement, Vibration Motor: adım 5, 2 resimden 2.
    • Remove the vibration motor visible in the front housing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tim Dascomb
159 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-34, Regan Spring 2010 Cal Poly, Team 26-34, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G34
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 11
Her zaman: 2,513
