Ana içeriğe geç
Sony Ericsson TM506 Motherboard Replacement
Neye ihtiyacın var
  1. Sony Ericsson TM506 Motherboard Replacement, Battery Cover: adım 1, 3 resimden 1. Sony Ericsson TM506 Motherboard Replacement, Battery Cover: adım 1, 3 resimden 2. Sony Ericsson TM506 Motherboard Replacement, Battery Cover: adım 1, 3 resimden 3.
    • Firmly hold the phone between your fingers with your thumb on the battery cover.
    • Push down with your thumb until the battery cover comes off.
  2. Sony Ericsson TM506 Motherboard Replacement, Back Case: adım 2, 3 resimden 1. Sony Ericsson TM506 Motherboard Replacement, Back Case: adım 2, 3 resimden 2. Sony Ericsson TM506 Motherboard Replacement, Back Case: adım 2, 3 resimden 3.
    • Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
  3. Sony Ericsson TM506 Motherboard Replacement: adım 3, 2 resimden 1. Sony Ericsson TM506 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the two rubber casings for the top two screws with a plastic opening tool.
  4. Sony Ericsson TM506 Motherboard Replacement: adım 4, 1 resimden 1.
    • Unscrew these two 5.4mm screws with a Torx T6 screwdriver.
  5. Sony Ericsson TM506 Motherboard Replacement: adım 5, 3 resimden 1. Sony Ericsson TM506 Motherboard Replacement: adım 5, 3 resimden 2. Sony Ericsson TM506 Motherboard Replacement: adım 5, 3 resimden 3.
    • There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
  6. Sony Ericsson TM506 Motherboard Replacement, Sound Box: adım 6, 3 resimden 1. Sony Ericsson TM506 Motherboard Replacement, Sound Box: adım 6, 3 resimden 2. Sony Ericsson TM506 Motherboard Replacement, Sound Box: adım 6, 3 resimden 3.
    • The sound box is attached to the case by two snap hooks.
    • Lift the sound box up to remove it from the case.
  7. Sony Ericsson TM506 Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. Sony Ericsson TM506 Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Locate the 80-pin connector.
    • Carefully, lift up on the connector to separate it from the board.
  8. Sony Ericsson TM506 Motherboard Replacement: adım 8, 3 resimden 1. Sony Ericsson TM506 Motherboard Replacement: adım 8, 3 resimden 2. Sony Ericsson TM506 Motherboard Replacement: adım 8, 3 resimden 3.
    • There are two snap hooks that attach the motherboard to the case.
    • Using a plastic opening tool, carefully lift up on the motherboard to detach it.
    • The motherboard is extremely fragile. Try to be forceful yet delicate in the removal because it will not come off easily.
Sonuç
Daniel
83 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-1, Regan SU 2012 Cal Poly, Team 1-1, Regan SU 2012 üyesi
CPSU-REGAN-SU12S1G1
2 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 1,140
