Ana içeriğe geç
Sony Ericsson TM506 Sim Card Replacement
Neye ihtiyacın var
  1. Sony Ericsson TM506 Sim Card Replacement, Battery Cover: adım 1, 3 resimden 1. Sony Ericsson TM506 Sim Card Replacement, Battery Cover: adım 1, 3 resimden 2. Sony Ericsson TM506 Sim Card Replacement, Battery Cover: adım 1, 3 resimden 3.
    • Firmly hold the phone between your fingers with your thumb on the battery cover.
    • Push down with your thumb until the battery cover comes off.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Ericsson TM506 Sim Card Replacement, Back Case: adım 2, 3 resimden 1. Sony Ericsson TM506 Sim Card Replacement, Back Case: adım 2, 3 resimden 2. Sony Ericsson TM506 Sim Card Replacement, Back Case: adım 2, 3 resimden 3.
    • Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Ericsson TM506 Sim Card Replacement: adım 3, 2 resimden 1. Sony Ericsson TM506 Sim Card Replacement: adım 3, 2 resimden 2.
    • Remove the two rubber casings for the top two screws with a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Ericsson TM506 Sim Card Replacement: adım 4, 1 resimden 1.
    • Unscrew these two 5.4mm screws with a Torx T6 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Sony Ericsson TM506 Sim Card Replacement: adım 5, 3 resimden 1. Sony Ericsson TM506 Sim Card Replacement: adım 5, 3 resimden 2. Sony Ericsson TM506 Sim Card Replacement: adım 5, 3 resimden 3.
    • There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
    FixBot'a Sor
    Yorum Ekle
  6. Sony Ericsson TM506 Sim Card Replacement, Sim Card: adım 6, 2 resimden 1. Sony Ericsson TM506 Sim Card Replacement, Sim Card: adım 6, 2 resimden 2.
    • The Sim card can simply be pulled out through the opening.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Daniel
83 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-1, Regan SU 2012 Cal Poly, Team 1-1, Regan SU 2012 üyesi
CPSU-REGAN-SU12S1G1
2 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 35
Her zaman: 1,836
