Ana içeriğe geç
Sony Ericsson W200i Back Case Replacement
Neye ihtiyacın var
  1. Sony Ericsson W200i Back Case Replacement, Disassembling Sony Ericsson W200i Battery: adım 1, 2 resimden 1. Sony Ericsson W200i Back Case Replacement, Disassembling Sony Ericsson W200i Battery: adım 1, 2 resimden 2.
    • Slide the battery cover up and off the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Ericsson W200i Back Case Replacement: adım 2, 2 resimden 1. Sony Ericsson W200i Back Case Replacement: adım 2, 2 resimden 2.
    • Pop the battery out of its slot by lifting it up.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Ericsson W200i Back Case Replacement, Front Case: adım 3, 3 resimden 1. Sony Ericsson W200i Back Case Replacement, Front Case: adım 3, 3 resimden 2. Sony Ericsson W200i Back Case Replacement, Front Case: adım 3, 3 resimden 3.
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Ericsson W200i Back Case Replacement, Core: adım 4, 2 resimden 1. Sony Ericsson W200i Back Case Replacement, Core: adım 4, 2 resimden 2.
    • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
    • Note that the top 2 screws are silver and the bottom 2 screws are black.
    FixBot'a Sor
    Yorum Ekle
  5. Sony Ericsson W200i Back Case Replacement: adım 5, 3 resimden 1. Sony Ericsson W200i Back Case Replacement: adım 5, 3 resimden 2. Sony Ericsson W200i Back Case Replacement: adım 5, 3 resimden 3.
    • There is a black tab in the top left corner holding the core in place.
    • Remove the core by pulling straight up to prevent breaking the tab.
    FixBot'a Sor
    Yorum Ekle
  6. Sony Ericsson W200i Back Case Replacement, Back Case: adım 6, 3 resimden 1. Sony Ericsson W200i Back Case Replacement, Back Case: adım 6, 3 resimden 2. Sony Ericsson W200i Back Case Replacement, Back Case: adım 6, 3 resimden 3.
    • Pull back on the indicated tab of the white plastic cover to unhook it from the top of the phone.
    • Using the plastic opening tool, undo the indicated clip on the bottom of the white plastic cover.
    • Remove the white plastic cover.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, put removed pieces into the new back casing, then follow the steps in reverse order.
Emily Prescott
531 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-10, Forte Winter 2011 Cal Poly, Team 14-10, Forte Winter 2011 üyesi
CPSU-FORTE-W11S14G10
5 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 4,097
