Ana içeriğe geç
Sony Ericsson W200i Back Case Replacement
Neye ihtiyacın var
  1. Sony Ericsson W200i Back Case Replacement, Disassembling Sony Ericsson W200i Battery: adım 1, 2 resimden 1. Sony Ericsson W200i Back Case Replacement, Disassembling Sony Ericsson W200i Battery: adım 1, 2 resimden 2.
    • Slide the battery cover up and off the phone.
  2. Sony Ericsson W200i Back Case Replacement: adım 2, 2 resimden 1. Sony Ericsson W200i Back Case Replacement: adım 2, 2 resimden 2.
    • Pop the battery out of its slot by lifting it up.
  3. Sony Ericsson W200i Back Case Replacement, Front Case: adım 3, 3 resimden 1. Sony Ericsson W200i Back Case Replacement, Front Case: adım 3, 3 resimden 2. Sony Ericsson W200i Back Case Replacement, Front Case: adım 3, 3 resimden 3.
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
  4. Sony Ericsson W200i Back Case Replacement, Core: adım 4, 2 resimden 1. Sony Ericsson W200i Back Case Replacement, Core: adım 4, 2 resimden 2.
    • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
    • Note that the top 2 screws are silver and the bottom 2 screws are black.
  5. Sony Ericsson W200i Back Case Replacement: adım 5, 3 resimden 1. Sony Ericsson W200i Back Case Replacement: adım 5, 3 resimden 2. Sony Ericsson W200i Back Case Replacement: adım 5, 3 resimden 3.
    • There is a black tab in the top left corner holding the core in place.
    • Remove the core by pulling straight up to prevent breaking the tab.
  6. Sony Ericsson W200i Back Case Replacement, Back Case: adım 6, 3 resimden 1. Sony Ericsson W200i Back Case Replacement, Back Case: adım 6, 3 resimden 2. Sony Ericsson W200i Back Case Replacement, Back Case: adım 6, 3 resimden 3.
    • Pull back on the indicated tab of the white plastic cover to unhook it from the top of the phone.
    • Using the plastic opening tool, undo the indicated clip on the bottom of the white plastic cover.
    • Remove the white plastic cover.
Sonuç
To reassemble your device, put removed pieces into the new back casing, then follow the steps in reverse order.
Emily Prescott
531 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-10, Forte Winter 2011 Cal Poly, Team 14-10, Forte Winter 2011 üyesi
CPSU-FORTE-W11S14G10
5 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 14
Her zaman: 3,653
