Giriş
Replacing the keypad requires that the front case be removed.
Neye ihtiyacın var
Slide the battery cover up and off the phone.
Insert the plastic opening tool in between the front case and the back case.
Apply downward pressure to make the case lift upwards, thus popping the front case off.
Using the plastic opening tool, press down anywhere on the keypad to separate it from the front case.
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Can you guys tell me where i do get parts for these legacy phones?My jostick died on this phone.Not working at all i only can use the keypad.
