Ana içeriğe geç
Sony Ericsson W580i LCD Replacement
Neye ihtiyacın var
    1. Sony Ericsson W580i LCD Replacement, Front Cover: adım 1, 2 resimden 1. Sony Ericsson W580i LCD Replacement, Front Cover: adım 1, 2 resimden 2.
      • Insert the edge of an opening tool between the front cover and the phone.
      • Gently pry off the front cover working your way around the edges.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Ericsson W580i LCD Replacement: adım 2, 2 resimden 1. Sony Ericsson W580i LCD Replacement: adım 2, 2 resimden 2.
      • Pull the front cover down and away from the phone.
      • The front keypads might come off with the front cover. Do not lose these.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Ericsson W580i LCD Replacement: adım 3, 1 resimden 1.
      • Gently peel the keypad away from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Ericsson W580i LCD Replacement, LCD: adım 4, 2 resimden 1. Sony Ericsson W580i LCD Replacement, LCD: adım 4, 2 resimden 2.
      • Insert a spudger between the lower edge of the screen and the phone.
      • Pry the screen up to disconnect the tabs on each side holding the screen in.
      • Do not remove the screen yet. There is a ribbon connecting the screen to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Ericsson W580i LCD Replacement: adım 5, 2 resimden 1. Sony Ericsson W580i LCD Replacement: adım 5, 2 resimden 2.
      • Use a spudger to remove the ribbon cable from the motherboard.
      • Lift the screen away from the phone
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Diego
397 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-31, Amido Fall 2011 Cal Poly, Team 5-31, Amido Fall 2011 üyesi
CPSU-AMIDO-F11S5G31
4 Üyeler
66 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 6,253
