Ana içeriğe geç
Sony Ericsson W810I Camera Lens Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Sony Ericsson W810I Camera Lens Replacement, Camera Lens: adım 1, 1 resimden 1.
    • Ensure the phone is switched off. Then press down firmly against the Cingular icon with your thumb.
    • Slide the panel down and remove the latch
  2. Sony Ericsson W810I Camera Lens Replacement: adım 2, 2 resimden 1. Sony Ericsson W810I Camera Lens Replacement: adım 2, 2 resimden 2.
    • Lift the battery with your fingers and pull it out of the casing.
    • Remove the SIM card as well if you have one
  3. Sony Ericsson W810I Camera Lens Replacement: adım 3, 1 resimden 1.
    • Remove the two outer screws using a T7 Torx screwdriver.
  4. Sony Ericsson W810I Camera Lens Replacement: adım 4, 1 resimden 1.
    • Remove the two smaller inner screws with the Mini-Phillips screwdriver.
  5. Sony Ericsson W810I Camera Lens Replacement: adım 5, 2 resimden 1. Sony Ericsson W810I Camera Lens Replacement: adım 5, 2 resimden 2.
    • Remove the back faceplate on the camera side with the blue hand wedge.
  6. Sony Ericsson W810I Camera Lens Replacement: adım 6, 3 resimden 1. Sony Ericsson W810I Camera Lens Replacement: adım 6, 3 resimden 2. Sony Ericsson W810I Camera Lens Replacement: adım 6, 3 resimden 3.
    • Flip the phone over and pry off the front faceplate using multiple blue hand-wedges.
    • Separate the keypad from the logic board by turning it upside down and allowing it to fall into your hand.
  7. Sony Ericsson W810I Camera Lens Replacement: adım 7, 1 resimden 1.
    • Remove the two remaining screws at the top corners of the phone.
  8. Sony Ericsson W810I Camera Lens Replacement: adım 8, 1 resimden 1.
    • Remove the logic board with multiple blue hand-wedges. Prise the logic board away carefully to avoid damaging it or snapping the wiring.
  9. Sony Ericsson W810I Camera Lens Replacement: adım 9, 1 resimden 1.
    • From the inside of the panel, press down on the camera lens to pop it out of its mounting.
    • Replace the lens and reverse the process to reassemble the device.
Sonuç
Ben Micucci
186 İtibar
5 adet Kılavuz yazıldı
Ekip
James Madison, Team 2-2, Allen Fall 2011 James Madison, Team 2-2, Allen Fall 2011 üyesi
JMU-ALLEN-F11S2G2
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,412
