Neye ihtiyacın var
Place your Sony Ericsson W810I screen side down with the battery cover facing up as shown.
Remove the two 3.9mm screws with a Phillips size #00 screwdriver.
Remove the two 6.35mm screws with a Torx T6 screwdriver.
Peel the rubber keys away from their backing. Do not slide them off.
Set them aside.
Using a plastic opening device, push against the underside of the brown portion of the the ribbon cable to unplug it.
Push against the underside of the ribbon cable at the point of attachment with a plastic opening tool until it detaches.
Bir başkası bu kılavuzu tamamladı.
