Ana içeriğe geç
Sony Ericsson W810I Charger Adapter Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Sony Ericsson W810I Charger Adapter Replacement, Charger Adapter: adım 1, 1 resimden 1.
    • Power the phone off.
    • Press down firmly against the icon on the lower rear panel with your thumb.
    • Slide the panel down to remove it.
  2. Sony Ericsson W810I Charger Adapter Replacement: adım 2, 2 resimden 1. Sony Ericsson W810I Charger Adapter Replacement: adım 2, 2 resimden 2.
    • Lift the battery and pull it out.
    • Remove the SIM card too if you have one.
  3. Sony Ericsson W810I Charger Adapter Replacement: adım 3, 2 resimden 1. Sony Ericsson W810I Charger Adapter Replacement: adım 3, 2 resimden 2.
    • Remove the following screws:
    • Two T7 Torx screws
    • Two Phillips #00 screws
  4. Sony Ericsson W810I Charger Adapter Replacement: adım 4, 2 resimden 1. Sony Ericsson W810I Charger Adapter Replacement: adım 4, 2 resimden 2.
    • Use an opening tool to remove the camera faceplate.
    • Be careful to not bend the camera faceplate when removing it.
  5. Sony Ericsson W810I Charger Adapter Replacement: adım 5, 3 resimden 1. Sony Ericsson W810I Charger Adapter Replacement: adım 5, 3 resimden 2. Sony Ericsson W810I Charger Adapter Replacement: adım 5, 3 resimden 3.
    • Flip the phone over and use an opening tool to pry off the number pad.
    • Separate the keypad from the motherboard.
  6. Sony Ericsson W810I Charger Adapter Replacement: adım 6, 1 resimden 1.
    • Remove two T6 Torx screws that secure the motherboard.
    • Use an opening tool to remove the motherboard. Pay attention to cables on the motherboard.
    • Do not pry too hard on the motherboard, as it can break under too much force.
  7. Sony Ericsson W810I Charger Adapter Replacement: adım 7, 1 resimden 1.
    • Pull off charger adapter and remove it.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ben Micucci
186 İtibar
5 adet Kılavuz yazıldı
Ekip
James Madison, Team 2-2, Allen Fall 2011 James Madison, Team 2-2, Allen Fall 2011 üyesi
JMU-ALLEN-F11S2G2
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,620
