Ana içeriğe geç
Sony Ericsson Xperia Play LCD Display Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: adım 1, 3 resimden 1. Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: adım 1, 3 resimden 2. Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: adım 1, 3 resimden 3.
    • Remove the battery cover and the battery.
    • You have the 6x silver screws and 7x black screws and you can remove the rear bezel.
  2. Sony Ericsson Xperia Play LCD Display Replacement: adım 2, 3 resimden 1. Sony Ericsson Xperia Play LCD Display Replacement: adım 2, 3 resimden 2. Sony Ericsson Xperia Play LCD Display Replacement: adım 2, 3 resimden 3.
    • By using a plastic tool, disconnect the main flex cable connector. Be careful, near to the connector there are many small elements.
    • Disconnect the gaming keyboard flex cable.
  3. Sony Ericsson Xperia Play LCD Display Replacement: adım 3, 2 resimden 1. Sony Ericsson Xperia Play LCD Display Replacement: adım 3, 2 resimden 2.
    • Remove the motherboard and the gaming keyboard.
  4. Sony Ericsson Xperia Play LCD Display Replacement: adım 4, 3 resimden 1. Sony Ericsson Xperia Play LCD Display Replacement: adım 4, 3 resimden 2. Sony Ericsson Xperia Play LCD Display Replacement: adım 4, 3 resimden 3.
    • Unscrew the 4x black screws.
    • Remove the black sticker on the corner and disconnect the touchscreen flex cable.
    • Disassemble front bezel.
  5. Sony Ericsson Xperia Play LCD Display Replacement: adım 5, 3 resimden 1. Sony Ericsson Xperia Play LCD Display Replacement: adım 5, 3 resimden 2. Sony Ericsson Xperia Play LCD Display Replacement: adım 5, 3 resimden 3.
    • Use the thin side of a plastic tool to separate the LCD display from the base bezel.
    • Now you are ready to install the new spare part.
    • I prefer to test the new spare part before the full assembly.
  6. Sony Ericsson Xperia Play LCD Display Replacement: adım 6, 1 resimden 1.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
ZFix
191.308 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.532 adet Kılavuz yazıldı
Bir Yorum
Do you have a datasheet for the display? I wanted to reuse it but i cannot find the function of the pins.
jp r - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 4,999
