Ana içeriğe geç
Sony Ericsson Xperia Play Main Flex Cable Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Sony Ericsson Xperia Play Main Flex Cable Replacement, Main Flex Ribbon Cable: adım 1, 3 resimden 1. Sony Ericsson Xperia Play Main Flex Cable Replacement, Main Flex Ribbon Cable: adım 1, 3 resimden 2. Sony Ericsson Xperia Play Main Flex Cable Replacement, Main Flex Ribbon Cable: adım 1, 3 resimden 3.
    • Remove the battery cover and the battery.
    • You have 6x silver screw and 7x black screw and remove the rear bezel.
  2. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 2, 2 resimden 1. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 2, 2 resimden 2.
    • Now with a plastic tool disconnect the main flex cable. Be careful, near to the main flex cable connector there is many small elements.
    • Disconnect the gaming keyboard flex keyboard.
  3. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 3, 2 resimden 1. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 3, 2 resimden 2.
    • Remove the mother board and the gaming keyboard.
  4. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 4, 3 resimden 1. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 4, 3 resimden 2. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 4, 3 resimden 3.
    • Unscrew the 4x screws.
    • Remove the black sticker.
    • Disconnect the touchscreen flex cable connector.
    • Now you can disassemble the front bezel.
  5. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 5, 2 resimden 1. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 5, 2 resimden 2.
    • Use the thin end of a plastic tool to remove LCD Display and disconnect the flex cable.
  6. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 6, 3 resimden 1. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 6, 3 resimden 2. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 6, 3 resimden 3.
    • To release the ribbon cable peel off two patches.
  7. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 7, 3 resimden 1. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 7, 3 resimden 2. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 7, 3 resimden 3.
    • Now remove the small metal plate taped to the flex cable.
    • Remove the plastic plate from the back side of the flex cable connector.
    • Bend the cable at an angle so you can push it down through the hole.
  8. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 8, 3 resimden 1. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 8, 3 resimden 2. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 8, 3 resimden 3.
    • Use the same technique when you are installing the new Main Ribbon Cable.
    • I prefer to test the new spare part before the full assembly.
  9. Sony Ericsson Xperia Play Main Flex Cable Replacement: adım 9, 1 resimden 1.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
ZFix
191.308 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.535 adet Kılavuz yazıldı
3 Yorum
Iv got a problem my phone won't turn on or charge but when i plug the charger in the power button just flashes red a couple of times then nothing do u know what this means is it the battery or the phone that is broke
paulfrost412 - Yanıt
Is "small metal plate" from Step 7 important? Forgot to put it inside and if there is no need to open it again (everything works) I won't do it :)
ch3mn3y - Yanıt
vreau sa cumpar sleif la xperia play, rog foarte muld daca aveti ceva informatii sunati sau scrieti pe mob; 060215747.
petrea - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 20
Son 30 gün: 51
Her zaman: 7,400
