Ana içeriğe geç
Sony Ericsson Xperia Pro MK16A Power Button Replacement
Neye ihtiyacın var
  1. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: adım 1, 3 resimden 1. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: adım 1, 3 resimden 2. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: adım 1, 3 resimden 3.
    • Use a plastic opening tool to get the back cover off your phone.
    • The plastic opener will work on any side, but be careful and pry gently.
  2. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Removing the Battery: adım 2, 1 resimden 1.
    • Locate the battery in your phone.
    • Find the divot below the battery.
    • Use your thumb to lift the battery out of the phone.
  3. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: adım 3, 3 resimden 1. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: adım 3, 3 resimden 2. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: adım 3, 3 resimden 3.
    • Remove the 4 black screws with the Phillips screwdriver.
    • Remove the 4 silver screws with the Torx screwdriver.
  4. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Back Case: adım 4, 1 resimden 1.
    • Insert the plastic opening tool in between the two halves of the case. Pry around the phone to detach the back case.
  5. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Replacing the Power Button: adım 5, 2 resimden 1. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Replacing the Power Button: adım 5, 2 resimden 2.
    • When the inner back cover is off, locate and remove the power button.
Sonuç
John Emery
65 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-5, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-5, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 780
