Ana içeriğe geç
Sony Ericsson Xperia X10 Audio Jack Replacement
Neye ihtiyacın var
  1. Sony Ericsson Xperia X10 Audio Jack Replacement, Audio Jack: adım 1, 1 resimden 1.
    • The audio jack is located on the top side of the phone, in the center. To access the audio jack disassemble is necessary.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Ericsson Xperia X10 Audio Jack Replacement: adım 2, 1 resimden 1.
    • Start by having the screen of the phone facing downwards and remove the battery. Remove eight 5mm screws located as shown with a T-6 bit.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Ericsson Xperia X10 Audio Jack Replacement: adım 3, 1 resimden 1.
    • Using a case opener, start on the bottom right side of the phone and undo clips located at the interior sides. Repeat this step for the left side.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Ericsson Xperia X10 Audio Jack Replacement: adım 4, 1 resimden 1.
    • Once the clips are undone the back casing should dislocate and reveal the internal components of the phone. Audio jack location is identified on the image.
    FixBot'a Sor
    Yorum Ekle
  5. Sony Ericsson Xperia X10 Audio Jack Replacement: adım 5, 2 resimden 1. Sony Ericsson Xperia X10 Audio Jack Replacement: adım 5, 2 resimden 2.
    • The audio jack can only be accessed if the internal casing is removed. To remove this, apply pressure on the left side of internal casing and using a flat head screw driver unlatch both clips on the right side of casing.
    FixBot'a Sor
    Yorum Ekle
  6. Sony Ericsson Xperia X10 Audio Jack Replacement: adım 6, 2 resimden 1. Sony Ericsson Xperia X10 Audio Jack Replacement: adım 6, 2 resimden 2.
    • Audio Jack is located and easily removed. New component can be inserted.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bryan
410 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 49
Her zaman: 792
