Ana içeriğe geç
Sony Ericsson Xperia X10 Audio and Camera buttons Replacement
Neye ihtiyacın var
  1. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement, Audio and Camera buttons: adım 1, 1 resimden 1.
    • The first step in accessing the audio and/or camera buttons is to remove the back case of the phone and then the battery
  2. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement: adım 2, 1 resimden 1.
    • Use a Torx T6 screwdriver to remove eight 5 mm screws on the back case.
  3. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement: adım 3, 1 resimden 1.
    • Using an opening case, (a guitar pick works as well), start on the bottom right side of the phone and undo the clips located at the interior sides. Repeat this step for the left side.
  4. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement: adım 4, 1 resimden 1.
    • The phone should now look like this. The Volume button is indicated by the larger yellow circle, and the camera button is indicated by the smaller and lower yellow circle.
  5. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement: adım 5, 1 resimden 1.
    • The volume button (left) and the camera button (right) lift right out of the phone as shown in the picture. From here you can clean them or replace them.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nick E
149 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Shastany Fall 2013 UMass Dartmouth, Team 1-5, Shastany Fall 2013 üyesi
UMASSD-SHASTANY-F13S1G5
2 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 1,885
