Ana içeriğe geç
Sony Ericsson Z500a Keypad Replacement
Neye ihtiyacın var
  1. Sony Ericsson Z500a Keypad Replacement, Keypad: adım 1, 3 resimden 1. Sony Ericsson Z500a Keypad Replacement, Keypad: adım 1, 3 resimden 2. Sony Ericsson Z500a Keypad Replacement, Keypad: adım 1, 3 resimden 3.
    • Remove the back cover by pulling it down, and then take out the battery.
    • Using a T6 Torx screwdriver, remove the 4 screws.
    • Keep the phone open with the back cover facing you.
  2. Sony Ericsson Z500a Keypad Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool and run it between the case and the body of the device to loosen the keyboard
    • There are 2 clamps that lock the keyboard to the case (1 on each side)
  3. Sony Ericsson Z500a Keypad Replacement: adım 3, 1 resimden 1.
    • Flip the phone over and lift straight up on the key pad to remove it.
    • Be sure to hold the phone flat (parallel to the table) so that no loose parts fall out.
Sonuç
Jory Benitez
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-12, Maness Spring 2010 Cal Poly, Team 7-12, Maness Spring 2010 üyesi
CPSU-MANESS-S10S7G12
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 2,721
