Ana içeriğe geç
Giriş
This guide will show you how to install a battery in the Sony Ericsson s710a. It can be used if the current battery is missing or faulty and needs to be replaced.
Aletler
Hiçbir alet belirtilmedi.
Parçalar
  1. Remove the back cover by sliding it off.
    • Remove the back cover by sliding it off.
  2. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  3. Once the back cover is removed, pull out the battery using your finger as shown.
    • Once the back cover is removed, pull out the battery using your finger as shown.
  4. The battery can now be replaced if desired.
    • The battery can now be replaced if desired.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
Sonuç
Replacing the battery is a simple and effective way to get longer battery life.
Bir başkası bu kılavuzu tamamladı.
Mike
31 İtibar
2 adet Kılavuz yazıldı
Takım
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 2,208
