Ana içeriğe geç
Sony Ericsson xPeria Active Camera Replacement
Neye ihtiyacın var
  1. Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: adım 1, 3 resimden 1. Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: adım 1, 3 resimden 2. Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: adım 1, 3 resimden 3.
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Camera Replacement, Remove inside plastic battery cover.: adım 2, 2 resimden 1. Sony Ericsson xPeria Active Camera Replacement, Remove inside plastic battery cover.: adım 2, 2 resimden 2.
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Camera Replacement, Remove the battery: adım 3, 2 resimden 1. Sony Ericsson xPeria Active Camera Replacement, Remove the battery: adım 3, 2 resimden 2.
    • Remove the battery.
  4. Sony Ericsson xPeria Active Camera Replacement, Unfastening The Motherboard Cover: adım 4, 1 resimden 1.
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Camera Replacement, Removing The Motherboard Cover: adım 5, 2 resimden 1. Sony Ericsson xPeria Active Camera Replacement, Removing The Motherboard Cover: adım 5, 2 resimden 2.
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Camera Replacement, Unplug the back motherboard plug.: adım 6, 2 resimden 1. Sony Ericsson xPeria Active Camera Replacement, Unplug the back motherboard plug.: adım 6, 2 resimden 2.
    • Unplug the plug from the motherboard.
  7. Sony Ericsson xPeria Active Camera Replacement, Remove motherboard from device case.: adım 7, 1 resimden 1.
    • Using the plastic opening tool, carefully pry up on the edges of the motherboard, opposite of the jacks.
  8. Sony Ericsson xPeria Active Camera Replacement, Remove the display ribbon cable: adım 8, 2 resimden 1. Sony Ericsson xPeria Active Camera Replacement, Remove the display ribbon cable: adım 8, 2 resimden 2.
    • Carefully pry up on the tab holding down the display ribbon cable and remove the ribbon cable.
  9. Sony Ericsson xPeria Active Camera Replacement: adım 9, 2 resimden 1. Sony Ericsson xPeria Active Camera Replacement: adım 9, 2 resimden 2.
    • Use the plastic opening tool to pry the ribbon cable away from the motherboard.
  10. Sony Ericsson xPeria Active Camera Replacement, Remove camera from device: adım 10, 2 resimden 1. Sony Ericsson xPeria Active Camera Replacement, Remove camera from device: adım 10, 2 resimden 2.
    • Pull the camera out through the front of the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Tobin
406 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-5, Leahy Fall 2014 USF Tampa, Team 14-5, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G5
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 33
Her zaman: 850
