Giriş
The headphone jack will need to be replaced it it no longer outputs audio.
  1. Open the flaps and remove the back cover using the plastic opening device. Open the flaps and remove the back cover using the plastic opening device. Open the flaps and remove the back cover using the plastic opening device.
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Remove the battery shield with the plastic opening device. Remove the battery shield with the plastic opening device.
    • Remove the battery shield with the plastic opening device.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Remove the battery. Remove the battery.
    • Remove the battery.
  5. Unscrew the 5mm screws with the T5 head.
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  6. Remove the black cover with the plastic opening tool. Remove the headphone jack from its slot.
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
Sonuç
3 başka kişi bu kılavuzu tamamladı.
Daniel
427 İtibar
2 adet Kılavuz yazıldı
Takım
USF Tampa, Team 14-5, Leahy Fall 2014 USF Tampa, Team 14-5, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 4
Her zaman: 578
