Ana içeriğe geç
Sony Ericsson xPeria Active Headphone Jack Replacement
Neye ihtiyacın var
    1. Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the back cover.: adım 1, 3 resimden 1. Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the back cover.: adım 1, 3 resimden 2. Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the back cover.: adım 1, 3 resimden 3.
      • Open the flaps and remove the back cover using the plastic opening device.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Ericsson xPeria Active Headphone Jack Replacement, Remove inside plastic battery cover.: adım 2, 2 resimden 1. Sony Ericsson xPeria Active Headphone Jack Replacement, Remove inside plastic battery cover.: adım 2, 2 resimden 2.
      • Remove the battery shield with the plastic opening device.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the battery: adım 3, 2 resimden 1. Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the battery: adım 3, 2 resimden 2.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Ericsson xPeria Active Headphone Jack Replacement, Unfastening The Motherboard Cover: adım 4, 1 resimden 1.
      • Unscrew the 5mm screws with the T5 head.
      • Unscrew the 6mm screw with the T6 head.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Ericsson xPeria Active Headphone Jack Replacement, Removing The Motherboard Cover: adım 5, 2 resimden 1. Sony Ericsson xPeria Active Headphone Jack Replacement, Removing The Motherboard Cover: adım 5, 2 resimden 2.
      • Remove the black cover with the plastic opening tool.
      • Remove the headphone jack from its slot.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Daniel
440 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-5, Leahy Fall 2014 USF Tampa, Team 14-5, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G5
3 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 1,006
