Ana içeriğe geç
Sony Ericsson xPeria Active Screen Replacement
Neye ihtiyacın var
  1. Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: adım 1, 3 resimden 1. Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: adım 1, 3 resimden 2. Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: adım 1, 3 resimden 3.
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Screen Replacement, Remove inside plastic battery cover.: adım 2, 2 resimden 1. Sony Ericsson xPeria Active Screen Replacement, Remove inside plastic battery cover.: adım 2, 2 resimden 2.
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Screen Replacement, Remove the battery: adım 3, 2 resimden 1. Sony Ericsson xPeria Active Screen Replacement, Remove the battery: adım 3, 2 resimden 2.
    • Remove the battery.
  4. Sony Ericsson xPeria Active Screen Replacement, Unfastening The Motherboard Cover: adım 4, 1 resimden 1.
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Screen Replacement, Removing The Motherboard Cover: adım 5, 2 resimden 1. Sony Ericsson xPeria Active Screen Replacement, Removing The Motherboard Cover: adım 5, 2 resimden 2.
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Screen Replacement, Screen: adım 6, 2 resimden 1. Sony Ericsson xPeria Active Screen Replacement, Screen: adım 6, 2 resimden 2.
    • Unplug the power cable by carefully prying it away from the motherboard.
  7. Sony Ericsson xPeria Active Screen Replacement: adım 7, 2 resimden 1. Sony Ericsson xPeria Active Screen Replacement: adım 7, 2 resimden 2.
    • Remove the power strip on the back side of the motherboard.
  8. Sony Ericsson xPeria Active Screen Replacement, Remove back screen shield: adım 8, 2 resimden 1. Sony Ericsson xPeria Active Screen Replacement, Remove back screen shield: adım 8, 2 resimden 2.
    • Remove the shield.
  9. Sony Ericsson xPeria Active Screen Replacement, Remove the screen module: adım 9, 2 resimden 1. Sony Ericsson xPeria Active Screen Replacement, Remove the screen module: adım 9, 2 resimden 2.
    • Push the screen through the front of the case, gently.
    • It may be a little tough, just work your way around the edges of the screen until it separates from the main case.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Alex Tobin
406 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-5, Leahy Fall 2014 USF Tampa, Team 14-5, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G5
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
hi can you add explain
abdnour master2 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 30
Her zaman: 2,355
