Ana içeriğe geç
Sony Ericsson xPeria Active Speaker Replacement
Neye ihtiyacın var
  1. Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: adım 1, 3 resimden 1. Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: adım 1, 3 resimden 2. Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: adım 1, 3 resimden 3.
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Speaker Replacement, Remove inside plastic battery cover.: adım 2, 2 resimden 1. Sony Ericsson xPeria Active Speaker Replacement, Remove inside plastic battery cover.: adım 2, 2 resimden 2.
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Speaker Replacement, Remove the battery: adım 3, 2 resimden 1. Sony Ericsson xPeria Active Speaker Replacement, Remove the battery: adım 3, 2 resimden 2.
    • Remove the battery.
  4. Sony Ericsson xPeria Active Speaker Replacement, Unfastening The Motherboard Cover: adım 4, 1 resimden 1.
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Speaker Replacement, Removing The Motherboard Cover: adım 5, 2 resimden 1. Sony Ericsson xPeria Active Speaker Replacement, Removing The Motherboard Cover: adım 5, 2 resimden 2.
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Speaker Replacement, Speaker: adım 6, 2 resimden 1. Sony Ericsson xPeria Active Speaker Replacement, Speaker: adım 6, 2 resimden 2.
    • Carefully pry the power cable away from the motherboard.
  7. Sony Ericsson xPeria Active Speaker Replacement: adım 7, 1 resimden 1.
    • Pry the motherboard out of the case.
  8. Sony Ericsson xPeria Active Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the power cable from the backside of the motherboard.
  9. Sony Ericsson xPeria Active Speaker Replacement: adım 9, 1 resimden 1.
    • The speaker can be seen in the top middle area on the reverse of the screen.
  10. Sony Ericsson xPeria Active Speaker Replacement: adım 10, 1 resimden 1.
    • Use the plastic opening tool to carefully pry the speaker away from the phone.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Daniel
437 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-5, Leahy Fall 2014 USF Tampa, Team 14-5, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 860
