Ana içeriğe geç
Giriş
This guide will show you how to remove the Dark Grey case that allows you access to the Motherboard.
Parçalar
Hiçbir parça belirtilmedi.
  1. To remove the back cover, use your thumb to press down on the center of case and slide it off.
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Using a fingernail lift the battery out of the phone.
    • Using a fingernail lift the battery out of the phone.
  3. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Slide the sim card out with your thumb.
    • Slide the sim card out with your thumb.
  5. To remove the back case first remove the four screws shown with a T5 Torx screwdriver
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  6. Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  7. Lift up towards the bottom and slide the case off.
    • Lift up towards the bottom and slide the case off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Serventi
50 İtibar
13 adet Kılavuz yazıldı
Takım
Cal Poly, Team 5-15, Maness Fall 2010 Cal Poly, Team 5-15, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G15
4 Üyeler
26 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 1
Her zaman: 995
