Ana içeriğe geç
Sony Ericsson z300 Back Speaker Replacement
Neye ihtiyacın var
  1. Sony Ericsson z300 Back Speaker Replacement, Back Phone Cover: adım 1, 1 resimden 1.
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Back Speaker Replacement, Battery: adım 2, 1 resimden 1.
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Back Speaker Replacement, Sim Card: adım 3, 1 resimden 1.
    • Slide the sim card out with your thumb.
  4. Sony Ericsson z300 Back Speaker Replacement, Back Dark Grey Case: adım 4, 1 resimden 1.
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  5. Sony Ericsson z300 Back Speaker Replacement: adım 5, 1 resimden 1.
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  6. Sony Ericsson z300 Back Speaker Replacement: adım 6, 1 resimden 1.
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Back Speaker Replacement, Back Speaker: adım 7, 1 resimden 1.
    • Use a plastic opening tool to lift the speaker out of the back case.
Sonuç
Alex Serventi
65 İtibar
13 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-15, Maness Fall 2010 Cal Poly, Team 5-15, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G15
4 Üyeler
26 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 934
