Ana içeriğe geç
Sony Ericsson z300 Front Speaker Replacement
Neye ihtiyacın var
  1. Sony Ericsson z300 Front Speaker Replacement, Back Phone Cover: adım 1, 1 resimden 1.
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Front Speaker Replacement, Battery: adım 2, 1 resimden 1.
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Front Speaker Replacement, Front Phone Cover: adım 3, 1 resimden 1.
    • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
  4. Sony Ericsson z300 Front Speaker Replacement, Front Dark Grey Case: adım 4, 1 resimden 1.
    • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
  5. Sony Ericsson z300 Front Speaker Replacement: adım 5, 1 resimden 1.
    • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
  6. Sony Ericsson z300 Front Speaker Replacement: adım 6, 1 resimden 1.
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Front Speaker Replacement, Screens: adım 7, 1 resimden 1.
    • Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
  8. Sony Ericsson z300 Front Speaker Replacement: adım 8, 1 resimden 1.
    • Lift the ribbon cable connector lock using a plastic opening tool.
  9. Sony Ericsson z300 Front Speaker Replacement: adım 9, 2 resimden 1. Sony Ericsson z300 Front Speaker Replacement: adım 9, 2 resimden 2.
    • Slide the black ribbon cable tray out with a plastic opening tool.
    • Shown in the second picture is the try already slid out.
  10. Sony Ericsson z300 Front Speaker Replacement: adım 10, 2 resimden 1. Sony Ericsson z300 Front Speaker Replacement: adım 10, 2 resimden 2.
    • Slide the ribbon cable out of the connector.
    • Shown in the second picture is the cable already out.
  11. Sony Ericsson z300 Front Speaker Replacement: adım 11, 1 resimden 1.
    • Use a plastic opening tool to lift up on the screen board and release the clips holding it in place.
    • Lift the entire board out of the phone to remove both screens.
  12. Sony Ericsson z300 Front Speaker Replacement, Front Speaker: adım 12, 1 resimden 1.
    • Use a plastic opening tool to lift the speaker out of its circular slot.
Sonuç
Alex Serventi
65 İtibar
13 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-15, Maness Fall 2010 Cal Poly, Team 5-15, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G15
4 Üyeler
26 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,561
