Ana içeriğe geç
Sony Ericsson z300 Keypad Replacement
Neye ihtiyacın var
  1. Sony Ericsson z300 Keypad Replacement, Back Phone Cover: adım 1, 1 resimden 1.
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Ericsson z300 Keypad Replacement, Battery: adım 2, 1 resimden 1.
    • Using a fingernail lift the battery out of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Ericsson z300 Keypad Replacement, Sim Card: adım 3, 1 resimden 1.
    • Slide the sim card out with your thumb.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Ericsson z300 Keypad Replacement, Back Dark Grey Case: adım 4, 1 resimden 1.
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
    FixBot'a Sor
    Yorum Ekle
  5. Sony Ericsson z300 Keypad Replacement: adım 5, 1 resimden 1.
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
    FixBot'a Sor
    Yorum Ekle
  6. Sony Ericsson z300 Keypad Replacement: adım 6, 1 resimden 1.
    • Lift up towards the bottom and slide the case off.
    FixBot'a Sor
    Yorum Ekle
  7. Sony Ericsson z300 Keypad Replacement, Motherboard: adım 7, 1 resimden 1.
    • Use a plastic opening tool to lift up the brass colored panel.
    FixBot'a Sor
    Yorum Ekle
  8. Sony Ericsson z300 Keypad Replacement: adım 8, 1 resimden 1.
    • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
    FixBot'a Sor
    Yorum Ekle
  9. Sony Ericsson z300 Keypad Replacement: adım 9, 1 resimden 1.
    • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
    FixBot'a Sor
    Yorum Ekle
  10. Sony Ericsson z300 Keypad Replacement, Keypad: adım 10, 1 resimden 1.
    • Using a plastic opening tool lift up the keypad to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Serventi
65 İtibar
13 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-15, Maness Fall 2010 Cal Poly, Team 5-15, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G15
4 Üyeler
39 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 1,628
