Ana içeriğe geç
Sony Ericsson z300 Motherboard Replacement
Neye ihtiyacın var
  1. Sony Ericsson z300 Motherboard Replacement, Back Phone Cover: adım 1, 1 resimden 1.
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Motherboard Replacement, Battery: adım 2, 1 resimden 1.
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Motherboard Replacement, Sim Card: adım 3, 1 resimden 1.
    • Slide the sim card out with your thumb.
  4. Sony Ericsson z300 Motherboard Replacement, Back Dark Grey Case: adım 4, 1 resimden 1.
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  5. Sony Ericsson z300 Motherboard Replacement: adım 5, 1 resimden 1.
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  6. Sony Ericsson z300 Motherboard Replacement: adım 6, 1 resimden 1.
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Motherboard Replacement, Motherboard: adım 7, 1 resimden 1.
    • Use a plastic opening tool to lift up the brass colored panel.
  8. Sony Ericsson z300 Motherboard Replacement: adım 8, 1 resimden 1.
    • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
  9. Sony Ericsson z300 Motherboard Replacement: adım 9, 1 resimden 1.
    • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Serventi
65 İtibar
13 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-15, Maness Fall 2010 Cal Poly, Team 5-15, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G15
4 Üyeler
26 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 10
Her zaman: 2,151
