Ana içeriğe geç
Sony FDL-220R Watchman Antenna Replacement
Neye ihtiyacın var
  1. Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: adım 1, 2 resimden 1. Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: adım 1, 2 resimden 2.
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Antenna Replacement, Remove screws: adım 2, 2 resimden 1. Sony FDL-220R Watchman Antenna Replacement, Remove screws: adım 2, 2 resimden 2.
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  3. Sony FDL-220R Watchman Antenna Replacement, Remove back casing: adım 3, 2 resimden 1. Sony FDL-220R Watchman Antenna Replacement, Remove back casing: adım 3, 2 resimden 2.
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  4. Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: adım 4, 3 resimden 1. Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: adım 4, 3 resimden 2. Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: adım 4, 3 resimden 3.
    • Locate the two metal tabs which are meant to hold the antenna in place.
    • Pry back the metal tabs with a spudger.
    • Hook the antenna into the metal tab.
    • Ensure that the antenna is fully enclosed in the metal tab.
Sonuç
Sam Putnam
484 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-5, Williams Fall 2014 Baylor, Team 4-5, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S4G5
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 534
