Ana içeriğe geç
Sony FDL-220R Watchman Battery and Battery Contacts Replacement
Neye ihtiyacın var
  1. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove battery cover and batteries: adım 1, 2 resimden 1. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove battery cover and batteries: adım 1, 2 resimden 2.
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Inspect battery contacts in battery compartment: adım 2, 1 resimden 1.
    • Inspect battery contacts for any signs of damage.
    • Clean battery contacts with a solution of warm water and baking soda if there is corrosion.
  3. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove screws: adım 3, 2 resimden 1. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove screws: adım 3, 2 resimden 2.
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  4. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove back casing: adım 4, 2 resimden 1. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove back casing: adım 4, 2 resimden 2.
    • Grasp the entire back half of the Watchman's casing.
    • Snap off casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  5. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Inspect battery contacts on inside of back cover: adım 5, 1 resimden 1.
    • Inspect the two small springs on the back of the battery compartment.
    • Clean contacts with a solution of warm water and baking soda if there is corrosion.
Sonuç
Sam Putnam
484 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-5, Williams Fall 2014 Baylor, Team 4-5, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S4G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 530
