Ana içeriğe geç
Sony FDL-220R Watchman Button Replacement
Neye ihtiyacın var
  1. Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: adım 1, 2 resimden 1. Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: adım 1, 2 resimden 2.
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Button Replacement, Remove screws: adım 2, 2 resimden 1. Sony FDL-220R Watchman Button Replacement, Remove screws: adım 2, 2 resimden 2.
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Philips #00 screwdriver.
  3. Sony FDL-220R Watchman Button Replacement, Remove back casing: adım 3, 2 resimden 1. Sony FDL-220R Watchman Button Replacement, Remove back casing: adım 3, 2 resimden 2.
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
  4. Sony FDL-220R Watchman Button Replacement, Remove circuit board: adım 4, 3 resimden 1. Sony FDL-220R Watchman Button Replacement, Remove circuit board: adım 4, 3 resimden 2. Sony FDL-220R Watchman Button Replacement, Remove circuit board: adım 4, 3 resimden 3.
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
  5. Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: adım 5, 2 resimden 1. Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: adım 5, 2 resimden 2.
    • Locate the thee plastic buttons/switches on the sides of the plastic grey casing.
    • Buttons/switches should be simply resting in their slots on the device.
    • Remove all three buttons/switches.
    • If the buttons/switches are dirty, clean them in warm water and dry thoroughly.
    • If one of the buttons/switches is broken, simply replace it with a new one.
    • When replacing, make sure that the slot on the switches faces up.
Sonuç
Sam Putnam
484 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-5, Williams Fall 2014 Baylor, Team 4-5, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S4G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 252
